E90 Nokia Maps Beta Problem
3 replies · 3,366 views · Started 06 May 2008
Hi Guys,
Need some help. Had installed The Nokia Maps Beta 2. Worked well all this time. Today the application wouldnt open and had a message telling me to go to Nokia.com/maps and download the latest version. Does the beta version have a limited life time?
As per instructions on Beta Page I deleted the e:/cities folder and went to the nokia.maps page. But it had the upgrade version which I tried to download and install. Installed ok. But again couldnt open the application.
Any ideas how I can get the application to install correctly and load. Any idea where I can download the original nokia maps and not the upgarde available on their website.
Any suggestions appreciated.
Regards
Nilesh😡
topiwala wrote:Hi Guys,
Regards
Nilesh😡
hi, I tried the NOKIA maps 2.0 beta on E90 yesterday!
It does work~
but it seems some problems: there is no problem for your first using it
but, the phone will go dead when you second using the NOKIA map!
I don't know why it happened!
anyway, the NOKIA map 2.0 beta can be used in E90, this is clear !
