How to: Link your smartphone and Windows Media Player by UPnP
19 replies · 17,495 views · Started 07 May 2008
In our latest tutorial, Ewan takes a look at setting up the relatively simple, yet very useful, Universal Plug and Play (UPnP) utility 'Home Media' on Nokia's Nseries devices and connecting it to your music collection via Windows Media Player.
This is interesting but what I'd like to know is how to use my N95 as a wifi remote for Windows Media.
@neilhoskins: Ubuntu has ushare which works well. apt-get install ushare, edit /etc/ushare.conf, run ushare and dance the night away 😊
Salling Clicker...
Not free but enables remote control of iTunes/WMP by Bluetooth, or Wi-Fi - exceedingly cool.
@Xerxes:
Maybe surprisingly, Windows Media Player is only (in uPNP terms) a server and not a player. The best option I've managed to find so far that does both is the software that comes on your N95 CD, which Nokia call Home Media Centre but is really a bundled version of Simple Center.
@topyli:
Thanks muchly. I really want to give this a try at home: must start having a sniff around the office for a redundant workstation with a nice big hard drive 😉
Veeoh wrote:Salling Clicker...
Yes, this is a very cool piece of software but beware, if you use Devicescape, they do not co-exist together. It's one or the other.
On Ubuntu, you don't need to install anything! Just enable the UPnP Sharing plugin in Rhythmbox 😉
Streaming doesn't work on the N95-3, even with firmware ver 11.2.009
Unregistered, yes that is noted in the article, you'll need the later firmwares for the N95 range to get streaming, you only have copy available at the moment.
I always wondered how does it work... Thanks Ewan, with your help I finally got it.
I have played around with Orb (www.orb.com) and found it pretty impressive. I seem to recall being also being able to play to the pc as well, and using the pc as a slideshow viewer for the pics on my n82. I currently use Winamp remote (which is a watered down version of Orb, and powered by Orb) In both cases I have been able to stream video to a N810 (not sure about the phone though). The problem with streaming video is just that it seems restricted to mpg (mpeg) and I have converted most of my dvds to divx or xvid. 😞
There are rumoured hifis that are upnp compatible. On the other hand a2dp streaming seems to also be taking off. So many options and formats, so little time. sigh
Apparently the max size of the file to be copied is not big. Even after setting "save location" to memory card, some 20MB videos cannot be copied (70Mb free phone memory, some 50MB free RAM at the moment of operation)
I installed the Home Media Server shipping with OVI suite on Windows Vista X64.
My N85 can browse, copy and play the file and shared library of my computer, but my computer cannot connect with N85's media library. N85 shows up in my Network, but media player does not show it in the available libraries.
Also, i cannot play songs via the N85 on the home network.
Can you draft a new article with an FP2 device, Windows Vista and the OVI's suite's Home Media Server?
Hi. I can only stream music and pictures, but not videos on the N95. Does anybody notice this?
my windows media player does not find any device.is the problem from device? should i put iy on a specific option or sth? please help me on [email][email protected][/email]
Sorry for posting to this very old thread, but seemingly there is very little info out there. N95 is not available any more, and seemingly 5800 and n97 both have lost the playing capability of upnp. I need a phone that can play music locally on the phone - while the music is on my laptop/ other upnp servers.
Can someone please confirm for following
- n85
- n97
- 5800 xm
Please add more to this list.
My pc is connected to modem via ethernet cable..!!
the modem has wi-fi..!!
helpme by mailing
rajaspidey[at]gmail[dot]com
