Nokia N95 8GB, MCGuider Installation
3 replies · 11,166 views · Started 11 May 2008
i bought the Nokia N95 8GB yesterday.
I already dowloaded the MCGuider Navigation software but i don't know how to install it on my mobile phone now.
Is anybody here who knows how to install ist?
I also have a 2 GB SD-Card, but i don't know how to put it inside.
Please can somebody helps me????
THX!!!
G_Anthony wrote:Hi,
THX!!!
McGuider is only available on SD Card. It is not a downloadable product.
Unless of course you have a pirate copy (which if you have downloaded it, it will be). Therefore you will get no help here.
If you purchase McGuider officially, you can contact McGuider Customer Support who will guide you through installation on to your N95 8GB.
Don't be a cheapskate. McGuider only costs �39.99 from Expansys.
Do the right thing.
He mentions he has the card, i suspect the navigation software is on this SDcard, and he is asking for help on how to get it from his card to his phone mass storage?
If the above is true, then contact customer support
He does'nt have it on a card he's saying he downloaded it and he want to know how to install it to his N95 8GB or is 2GB card so i suspect it is pirated version.
The 2nd and last sentence he writ confirms what i'm saying
"I already dowloaded the MCGuider Navigation software"
"I also have a 2 GB SD-Card, but i don't know how to put it inside."
