I've got my n95 since a few days now. I noticed that the battery meter is full almost always, unless i reboot it and it showes the correct amount of battery.
Also i noticed it takes about 2:20h to charge it from 0 to full. Is this normal? How much does your Nokia N95-1 take to charge fully?
I have the latest firmware(21.0.016) with the euro1 product ID.
What sort of use does your N95 get-? Heavy, light, occasional?
I'm running v21 on mine and am having the same "bug".
I haven't timed it but I thought it only took half an hour to charge to full.
I clocked about 2 hours to full charge mine from total zero. It's good to know that the phone don't do fast charge all the time. Normally, with li-ion battery, the charging politic is 80% fast and 20% slow charge. This is to preserve the battery life so that it will hold the charge longer over time. Just my 0.02.
well i have sorted it out
When i got my phone here in Romania, it was shipped from the UK with a UK charger + adaptor. This charger made it charge more slowly.
After all i used my Nokia n82's charger and it charged in 1 hour and half, also the battery indicator is back to normal as far as i see.
Thx all for the replies..
By the way, does anybody have a link or something to a modified back case for N95-1 that can support the BL-6F 1200 mah battery?
ty
