I don't find wireless overall earphones for my E90, that's why I'm asking.
Phone calls and audio files is OK - but radio doesn't work, even if there is one in E90. I've heard bad explanations, such as that the earphone cord is the antenna. But as a matter of fact I don't search explanations at all.
I love to get a solution.
Kurt
[email][email protected][/email]
www.personaleu.eu
That bad explanation you eard, are very good!!! The cord really works as antena inthe models that do not have FM antena incorporated (there are some model with it).
Solution, as you are looking for...
1-Can you use internet radio?
2- Have you tried both the ways, cord earphones and wireless earphone simultaneously?
jmvdinis wrote:That bad explanation you eard, are very good!!! The cord really works as antena inthe models that do not have FM antena incorporated (there are some model with it).Solution, as you are looking for...
1. No
2. I don't like those wires
It there any small 1cm or so special antenna for E90?
FM radios need an antenna. The E90 uses the wired headphones but if you don't you would need something of similar length.
Unless I'm very much mistaken, you won't be able to get a short antenna.
Even if you plugged in some sort of aerial lead, this would probably cause the phone to assume you wanted to use a wired headset, so your wireless headset wouldn't work anyway...
