N95 Wifi problem (reboot)
2 replies · 3,016 views · Started 17 May 2008
I have tried to look for a similar problem on the forum already but I could not find a helpful thread. Sorry if there is a similar thread already.
Basically, I have only just got this phone and tried out the wifi connectivity. After entering the access point code, the phone will start connecting and then reboot itself. I have tried this with two connections already and both cause the phone to reset.
I have read that a 'hard reset' on the phone might fix it... but I am skeptical. I also have the current firmware installed.
Can anyone help? Much appreciated.
Before trying a hard reset, I'd like to say that I managed to connect wirelessly to a public hotspot with no problems at all. It did not reset itself even once.
The only problem is connecting to adhoc networks from laptops.
