The E90 automatically assigns voice tags to contacts. This results in many errors when I try voice dialling. Is there any way to change the tags and assign my own?
Brianro
E90 Voicetags
I don't know if this will help You. I've had errors (phone hanged) when tried to use voice commands. Then I've find an option in menu>tools>voice comm>settings>remove voice adapts. The problem solved with this.
Cheers,
I think that E90 will learn with the use of voice tags. It will adapt his synthetic voice tags to your voice and star working fine...
