Change N95 8Gb For An N82 Black?
4 replies · 3,652 views · Started 31 May 2008
My N95 8Gb is getting in quite a bad way build quality wise so I want to replace it. I want much the same feature set especially modem mode as I use it as a modem for my Mac laptop. Other than the high SAR value would you say the N82 Black is the right replacement for this phone?
N82 should do for what you want if you want a change... in almost all ways what you're used to in a different form (plus that xenon flash of course!)
If any of you want to swap your N82 for a N95 8GB, get in touch with me through here. 😊
I like the N95, but I find that 'sliders' are not for me.
It's less than a month old.
Richard G wrote:N82 should do for what you want if you want a change... in almost all ways what you're used to in a different form (plus that xenon flash of course!)
i agree, just saving right now for an 8gb microsd for my black N82
