I'm wondering if any of you software guys is able to write a printer-driver for the P800 and this little nice device:
http://www.mobilemag.com/content/100/102/C1447/
any ideas?
any ideas?
For what would you need a printer driver? Just send the document to
BT/IR enabled printer and you are done 😃
(not all printers work though)
and whats about the printer I mentionned above?
An infrared connection means that the m-PRINT offers quick cable free printing � simply point the m-PRINT at your PDA and press print to run off memo pages, schedules, address book details and much more, all within seconds.
Says so in the text......................................................................
[quote="JyriK"]For what would you need a printer driver? Just send the document to
(not all printers work though)[/quote]
It would also be good if we can have usb printer drivers. Bear in mind that most printers are still not ir / bt enabled. But a number of them are now on usb, less those used in offices.
So imagine if we can print by connecting the p800 to one end of the data cable and a usb printer at the other. Better still, if there is a usb to parallel adapter, then the p800 can print on most printers with the data cable. This is what I call productivity. 😊
