Bluetooth USB Adapters ^^
36 replies · 8,454 views · Started 08 February 2003
OK. I've read enough *terrible* things about Bluetooth and Nokia 7650, so I'll make a clear question:
Does anybody know a Bluetooth USB Adapter that really works? I'm not talking about little tweaks/drivers, etc...
I was going to buy one, but after reading a few topics, I decided to wait, and if I don't find any solution, I'm going to buy IR... :-?
Thanx in advance
NAME YOUR COUNTRY!
IF your in the UK, the novatech branded USB Bluetooth device at www.novatech.co.uk works a dream, Its very competitivley priced. [The lowest proce USB Bluetooth Device I have seen so far].
I don't think it's so hard to make it work after all...
I already had an IR when I decided to take my chances and buy the Gigabyte BT dongle for 45euro. I had not heard of a success story with it before, but after reading this forum and using the latest windcom driver, it worked like a charm. Now I always carry it with me.. 😊
I have a 3com usb adaptor at work which works fine, thou my pcmcia card for the laptop will not allow sending from the phone.
Where can I get the latest widcomm driver?
My country? Belgium, but I don't think it makes much difference.
Petran: can you please tell me the model of your BT adapter and the site where you downloaded 'windcom' drivers [if you can explain why do he have to download new drivers, I would be greatful].
Thanx!
Gigabyte currently has one model, BTD-01.
I use widcomm version 1.3.2.7 which can be found HERE. (I searched this forum to find it, you could too!! I hadn't kept it!!)
It does not work well with the version included in the package, file sending does not work I think, that's why... New versions in anything fix bugs and add functionality, anyway.
And now:
So, does it work or not?
I think he meant that the drivers on the CD that came with BT didnt work.
But getting the new widcomm version 1.3.2.7 drivers helped.
So installing those drivers is the solution to make any BT usb adpater to work perfectly with the 7650?
[quote="JyriK"]I think he meant that the drivers on the CD that came with BT didnt work.
But getting the new widcomm version 1.3.2.7 drivers helped.[/quote]That's exactly what I meant... 😊
iam suing MSI uSB and it works like a charm. I know a lot of people that si satisfied with it as well. Also it is a CLASS I device meaning it has high power thus higher range of coverage.
For enabling, e.g., Billionton USB BT dongle with Widcomm to work with PC Suite, read here:
http://www.communicator.cz/agora/agora.nsf/0/C42A70A29706B9A1C1256C8B0066B402
We have a 3com usb bt model 3creb96-eu.
�20 more expensive than most others but works perfectly.
I don't think it uses widcomm drivers but it's own, perhaps thats why it works..
[quote="cgo"]iam suing MSI uSB and it works like a charm. I know a lot of people that si satisfied with it as well. Also it is a CLASS I device meaning it has high power thus higher range of coverage.[/quote]
can u please name the model number?
Does anyone know if this works when it comes to syncing Nokia 7650 with outlook and so on?
Anyone using it today who can tell pros and cons?
Regards,
Mindlight
Hello there ppl .. after much search in the local market ... i only managed to find the following BT devices ... so if anyone has used them and KNOW that they work with PC suit please advice me ...and they are:
* IO Gear GBU301 Bluetooth to USB Adapter (price is almost double the others)
* Bluetake BT009V (Crystal Series)
* Billionton USBBT02-X Bluetooth USB Adapter
* Someone has promised me an MSI BT ... but I don�t know which module ??
P.S. I use Windows XP, Home SP1
I am using Mitsumi BT Dongle, but with modified MSI drivers (from a post of this forum), also changed registry entry to allow sending both ways.
Works fine sending files to phone by right clicking on file and sending straight to phone
Sends files phone to PC
Works perfectly with Nokia PC Suite
couldn't ask for more, if anyone needs full detail of how to get it to work just ask
Could you please post the details as so far noone I know has been able to get the Mitsumi BT adapter to work with BT.
Bob
Yes that was me, I am still having problems logging in (I keep timing out and cannot get in without logging out and back into my work machine!!!)
Right here goes
1. Uninstall ANY instance of Bluetooth sw in your computer (Widcomm, Mitsumi BT Suite, Blue Manager.. watever)
2. Restart the computer (remember to unplug the mitsumi from the usb port)
3. Download the MSI Software (I haven't tried the rest yet but this one works fine for me)
http://download.msi.com.tw/support/dvr_exe/bt45.exe
4. Install the sw and restart your computer.
5. Plug in your mitsumi and go to your device manager.
6. You should see an unknown USB DEVICE.
7. Now here comes the real deal. Go to C:\Program Files\Microstar\Bluetooth Software\bin\btwusb.ini
8. Open that file with a notepad and edit the following line.
VID_0db0&PID_1967 to
VID_03EE&PID_641F
There are two instances of it. So change BOTH of them. This line is to allow windows to detect the mitsumi device that u plugged in.
9. Save and restart your computer.
10. Go to your device manager -> select the USB Device -> Reinstall driver
11. Select the microstar path that i have previously mentioned and choose btwusb.ini
12. Windows should install the necessary sw for it !!
13. Restart the comp again and go to your BT Places.
14. Do a search for devices and VOILA !!! You will see your 7650 !
To use with PC Suite
1. Click on the mRouter icon in the system tray and put a tick in the bluetooth boxes, mine is com port 8 but it may vary, if it doesn't connect straight away, untick and tick until it does.
2.You will see it connect, open PC Suite and your away and running.
To send files to PC (when pc suite is NOT connected) change the following
HKEY_CURRENT_USER\Software\Widcomm\BTConfig\Services\0004
In this key folder, you'll find another key, named:
"AcceptOther" <-- that (on those that cannot send files is set to '0x0000000'😉
Just set this key to 0x0000001.
Hope this works for you, as it works fine for me
any probs just ask
Thanks RatKat, you are a star
:angel:
Have a :bday: on me.
I havn't got the Mitsumi myself, but a collegue has, if it works for him I will investigate in one myself (as it is probably the cheepest on the market)
Bob
Hi, I currently bought an MSI USB bluetooth transcieving key. How can I make this work with my nokia 7650? can anyone please help me....
[quote="Ratkat"]Right here goes
VID_03EE&PID_641F
[/quote]
Woohoo!! Ratkat, you're a f*%king genius!!!! 😃 😃 😃
Your fix works! I don't believe it! Finally, I've been able to backup my phone via bluetooth with the Mitsumi adapter.
I really cannot thank you enough. Seriously.
Just out of interest, how on earth did you work out the changes that needed to be made to the btwusb.ini file ??
I Use the 3com Bluetooth USB adaptor 3CREB96-EU
It works perfectly with Nokia PCSuite 1.1.0
I run windows 98SE though
The setup was tricky but the following page solved all problems
http://www.ocworkbench.com/2002/nokia/7650review/p4.htm
For Windows XP, I think you need to upgrade to Nokia PC Suite 1.2.0 at
http://www.nokia.com/cda1/0.1080.2015.00.html
and also to firmware 4.46 ???
Wow I guess I'm not the only one. Now I know why Nokia was close to losing it all. Guess what -I made a formal complaint after they told me that the only specified Bluetooth device tested with the 7650 is from thier subsidary company Socket Com. Well- Bill Gates is not alone. It's a pcmcia card so rendered useless to my grunty, pleb like, un yuppified desktop.
I strongly advise all of you to make formal complaints to Nokia- I have.
Oh, I 'll try that Widcom driver upgrade! - Here's for crossing my fingers
Thumnmilk
I had the same reply from Nokia in South Africa.
I lodged my complaint, but I doubt if it will make a difference
Their reply was that although it might work with other Bluetooth adaptors, they can't say as they only tested it with Socket com pcmcia card. Very poor excuse I Think
Hi all,
I am also looking for everyone's expertice advise. I've seared the fourms for advice on USB Bluetooth Adapters and still cannot decided which one to get. I have narrowed it down to:
Belkin USB Adapter - �39.99
Bluetake BT007 Dongle - �49.98
MSI 6967 - �27.79
The prices don't matter, but thourght I'd put them up.
I have been told the Bluetake has quite an impressive range, the MSI is very small + the range is fairly good and the Belkin is good quality + has good range but depends on the other device.
I want to be able to use Bluetooth through about 3 walls. But I also want it to be somewhat portable. Basically, which one of these 3 do you think is the best for range (inc walls) and portability.
Don't know much about Bluetooth.
Can you please tell me your opinions on on these. Thank You!
