navigation problem
3 replies · 1,895 views · Started 11 August 2008
I have a n95 8gb and it came with 6 months free voice navigation, the navigation and everything worked fine but then i reformatted my phone and now the navigation part works with the maps, but theres no voice telling me when to turn and i do have the volume on , i dont no why or how that happened. does anyone no what the problem is or where the voice files are on my phone so i can check if there even installed?
Open maps then press options-settings-navigation and change the voice guidance to your language. Click ok then back out from that menu. You should get a prompt to download the language file (about 2-3mbs if I remember correctly.
