data transfer usb mode problem
3 replies · 3,948 views · Started 28 August 2008
alot of times when i try to connect my n95 to pc through data transfer mode it says unable to connect because mass memory is in use even thou i closed all the mass memory applications though taskman and now even when i reset my phone it still says same thing, is there an application or someway the phone can just close whatever application is open thats preventing it from accessing data transfer usb mode?
l1nknp4rk wrote:alot of times when i try to connect my n95 to pc through data transfer mode it says unable to connect because mass memory is in use even thou i closed all the mass memory applications though taskman and now even when i reset my phone it still says same thing, is there an application or someway the phone can just close whatever application is open thats preventing it from accessing data transfer usb mode?
where do you save your messsages? if you are using the memorycard, this will cause probs with data transfer
i have messages saved to phone memory, im also using the conversation application, would that have any effect? im not sure whether those messages are also saved to phone or mass memory but ive used data transfer in the past with this application and even when i close this application with taskman data transfer still doesnt work
Go to Messages > Options > Settings > Other select Phone Memory and then try connecting your phone.
