Maximum memory card for E51?
5 replies · 6,434 views · Started 29 August 2008
Hello,
I'm currently using a 2GB MicroSD card in my E51, but I'm starting to find space a little tight (I use the E51 as my portable media device).
I'm just wondering if there's a definitive limit on the size of MicroSD cards you can use in the E51?
I ask because I had read the maximum you could use was 4GB, although I've found at least one other source that says 8GB.
Thanks for reading.
Because the E51 is a Feature Pack 1 device,the max memory card at the moment is 8GB,but 16 & 32GB will most likely work as well. All FP1 devices support micrsoSDHC Cards...
Thanks for the feedback.
Actually, I should have reported back sooner. I bought a class 6 card and it's working great too.
