N95 8GB : How do you do a reboot with NO programs running?
5 replies · 7,818 views · Started 20 September 2008
Can I start my phone in 'safe mode' or similar, where it doesn't allow any auto starting programs to start?
I'm having that problem where I can't USB connect via 'Data transfer' as I just keep getting the error "Mass memory is being used by another application" even after a power reset.
I can't see any apps that are running.
PhoNetInfo shows just these tasks running if it's of any assistance with my connection issue:
PhoNetInfo - non-system
EiksrvBackdrop - non-system
[blank] - non-system
Standby
Telephone
Main - non-system
SysAp
SysAp - non-system
vcommandmanager
Carousel
Anykey
Autolock
Cheers for any thoughts.
PS: Txts are saved to phone memory
When you remove your ph from the comp. do you use the Safely Remove Hardware Icon found next to your clock on computer. Also if you press Ctrl alt Del on your computer you can see what programs are running. If you still see nothing be patient in reconecting as there seems to be a bit of a lag tim in disconecting & reconecting. Dont know if this will help you but Im sure some one will correct me if im wrong or missed the point or something. In the mean time here are some codes for you
* *#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345
* *#7370# (*#RES0#)- Reset your phone to the default factory settings. Usually you will need this code when you want to reset your phone back to the same condition when you got it for the first time. When the phone ask for security code, the default one is 12345.
Warning: Before you do reset the phone, make sure that you don�t have important data. Your data on the phone memory will be lost once you reset it.
There is another key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
Bro, I had the same problem. After two hours of removing programs and fiddling with other stuff it turned out to be the trial version of FS Caller, full screen caller. It has to be some program, good luck!
Do you use Mass Memory for your text messages?
If so, you will have to change it to phone memory.
bbayjohn: Thanks, but I'm just looking to do a fresh start / boot up.. don't wish to reset things yet.
adrian: Havn't ever use FSc, but thanks for the tip.
ian: No I don't.. I am aware of that issue to.
Still looking for the resolution hmm
Start up in Safe Mode (no 'auto start' apps will be running): Hold down the pencil key when you turn on the phone and hold it on until you have to enter your PIN code.
-havent tried it my self but found it elsewhere
