About 90% of the time i use this application i am unable to open the pic. After i save the pic. The app takes the pic just fine but when i try to open it in gallery it just has a broken icon where the pic should be and when i try to view the pic using xplorer it says unable to open file. Only sometimes does the pic come out ok and i can view it just fine. I have a n95 8gb
panoman
What version do you have
its version Bit-Side.PanoMan.v3.0.457.S60v3.SymbianOS9.1
You want 3.0.610.
i got the newer version. works perfect. thx 😊
