The Nokia N82 gets v30 too!
30 replies · 12,245 views · Started 22 September 2008
I'd been holding off on this until it was fully available - but now the Nokia N82 just got its v30 firmware upgrade too, following on from the v30 upgrades for N95 and N95 8GB, with similar (but not identical) improvements, namely more stable Flash Lite 3, Maps 2.0, new Music player visualisations and increased speed and overall performance, less sensitive auto-screen rotation, Share online 3.0, plus numerous other detailed fixes and improvements, including better battery life. Sadly, the dim display 'feature' hasn't been fixed. But with UDP (User Data Preservation) in place you shouldn't need to restore data or apps or settings. But - you know - an extra sync of your PIM data might be a good idea - just in case?
No, there's no N-Gage client. I'm guessing that the UDP (User Data Preservation - which works BRILLIANTLY, by the way) wouldn't play right with the replacement of the N-Gage stub with the full client.....
I have discovered one application - navigational program Naviexpert (www.naviexpert.pl) - that uses full screen brightness of N82. It's probably written in java. Full brightness works only in Naviexpert, if I switch to another app (with Naviexpert running in the background) brightness goes back to normal dim screen.
Hmmmm..... UDP may have seemed to work brilliantly, but something's not right under the hood.
Data's all there, apps are all there, but I'm getting crashes and freezes. This is what happens when you try combining system files from one OS version with another.... 8-(
Going to hard reset and rebuild, based on v30 etc.
Is there an option to NOT use UDP, i.e. do things the old-fashioned way and update the phone by completely replacing the old firmware?
hi there. do you know by what other N-series models UDP is also supported with the new 30.x FW? or is it just the N82? thanks.
Shame that now the search content spans 2 lines and they've added 'share online' on the active standby screen. Other than that, doesn't feel any faster than v20.
a long press on the # key no longer toggles the silent profile. Am I the only one ?
Steph
Steph
Works fine on mine!
N82
Product Code:0554980
Software v30.0.019 (updated 20Sep8)
Answers:
1) No, I don't have EVERY handset. But I do have most of the good ones 8-) And some are Rafe's.....!!
2) The hard reset procedure worked fine. Proving that UDP isn't the answer to everything - it certainly screwed up here. Personally, I think Nokia should keep user data and apps and some settings but delete most config files under the hood, to minimise this sort of incompatibility....
3) And yes, # to silence works fine here.
slitchfield wrote:.... Sadly, the dim display 'feature' hasn't been fixed....
My sentiments exactly(as I expressed over a week ago at SF when it was initially avail), it would have also been decent of Nokia to provide settings for the asr, like a very well known 3rd party freeware app imo.
I bought my N82 from Nokia UK and after installing V30.0.019 with product code 0558752 I keep getting text from Nokia saying that I can use the # for silent profile.
It doesn't work.
Is it worth chasing up on this with them?
Also after the update I've got 3 extra icons in the video centre "XMLTV" "NSN MOBILE TV" and "NSN VIDEO services"
Steve/Rafe/others in the know, is it available for all product codes now (bought mine here in the US)? Have never updated firmware before so not familiar with the process etc.
On the Active Standby the 'Search' one used to be on one line and is now on two, and now we have the 'Share Online' plugin forced upon us as well.
Sorry Nokia this is utter utter cack
The 'Search' and 'Share Online' active standby plugin's make the Active Standby un-usable for showing calendar appointments, as it can now only ever show one before it runs out of space.
When will Nokia wake up and allow users to select which plugins they want to display like on 'E' Series devices.
On the E71, 'Share online 3.0' is on firmware without the stupid bloody icons, why can't it be the same on the 'N' Series.
If you had the foresight to hack your N82 and add 'installserver.exe' (UDP keeps the hack working nicely) before you updated the firmware to V30 then you will find a nice little unsigned sis file on Symbian Freak that will remove the Search and Share-Online plugins.
If you didn't have the foresight, then currently your stuffed as once updated it is not possible at this time to hack the V30 firmware.
Cant find any obvious changes to my N82 except that there's an app called My Nokia which I dont remember having seen before. Incidently, My Nokia, when opened, says Service Not Available In Your Country (South Africa). Hilarious, isnt it?
I can change to silent mode with the # key.
Further to my previous post regarding the # silent profile key I've just recoded my mobile form 0558752 to 0554980 and this function now works.
I re-installed the latest firmware.
There Is New Application Called My Nokia & Snakes Game Is Pre-installed On Phone Memory
So the N95 (original) and the N95-8gb get the update but N95-3 (US version) does not? Boo!
After using a hacked phone for a month, I don't see myself going back to an unhacked phone even if that means not updating to v30 firmware. The certificate problems simply get on my nerves, I'm not updating till a working hack comes out.
Nokia, Why can't you add an advanced mode to the s60 devices where apps don't require a certificate and the user is free to do whatever he chooses to do?
finally did it for a 111.4mb upgrade,new features show a new my nokia icon in applications and search my content in active screen takes up two lines now which looks stupid,one more line share online in active screen,real player doesnt support flv as told but flash player does,anything else is still to be found out
My N82 works fine with the new software update.....Its good that the auto-rotation is slightly manageable than the previous.But one thing I observed is,when i add some songs to the phone memeory/memory card and do 'Refresh' in Music Player,in Added: 'n' previously it used to show the number of songs...i think now it is showing the number of albums added..Beczz i added 8 songs from a single album and in Added it showed up '1'.
after updating with latest ver maps stops working. help me
I upgraded to firmware v30 and i lost my flash player also when i use maps the phone will hang. Should i re install v30? Will i be able to do this?
i updated my n82 with v30. bit at d end when only 50 sec were left, msg appeared dat connection with phone has been lost.
wht shud i do now?????????
is there any reset code to reset the software???????????
now we have memory cards to accommodate for the picture and video files, so dont compress the pciture files so much!
