I was wondering whether some has any experience with the Nokia E65 and Dual SIM adapters?
I've tried almost every Magic SIM adapter (the cut-version): 16th generation, 20th generation...none of them seemed to work.
simore(.ch) seems to have a Dual SIM adapter especially for the E65, which is called 'Black 1'. It's rather expensive, but does it work?
I also heard different stories about 2G, 3G en USIM cards. Is it possible to use a Dual SIM adapter with a 2G en 3G SIM simultaneous?
Regards,
Robert
hi rmouwen
that may work with the simore one, I was using it in the paste with a N95 (Silver dual sim)
your e65 is given as compatible with their dual sim black silver gold
my black is now beeing retired :d have equiped my iphone with their brand new platinum dual sim to get guarantee 3G networks, very happy btw...
good luck on your choice but I have forgotten chinese basic products from long long time, they doesn't fit and work with last mobile phones 😉
the model dual SIM Holder I own
rodrigo33 wrote:hi rmouwenthat may work with the simore one, I was using it in the paste with a N95 (Silver dual sim)
the image, it is most finer than preceding series
Hi all,
Does anyone know if the SIMORE adapter for the Nokia E65 had the ability to use both lines at the same time?
I am new to this and I want to make my cell dual card.
Thanks.
