I've been playing with my mates SE P800 (DRIBBLE) and was wondering if like the P800, it would be possible to, instead of having a tiny thumbnail when the phone rings, to have a full sized image. Could it temporarily replace the wallpaper whilst the phone is ringing or something? The current size ones are just too small!
Full screen Caller ID Pictures
[quote="deepblue"]I've been playing with my mates SE P800 (DRIBBLE) and was wondering if like the P800, it would be possible to, instead of having a tiny thumbnail when the phone rings, to have a full sized image. Could it temporarily replace the wallpaper whilst the phone is ringing or something? The current size ones are just too small![/quote]
Been asked before, use search, look in FAQ, cant be done.
P.S. Its Drawl not dribble... is the term used.
Drawl...you mean drool?
how bout rythmic backlight when your phone rings? just like in other nokia.. is it possible?
Been asked before, use search, look in FAQ, cant be done.P.S. Its Drawl not dribble... is the term used.
Very authoritive tone you've taken on there Zipper, especially since it can be done, its just not very likely to reach the general release stage due to the memory constraints of the 7650. The first Beta of Live panel (later became One2go) had all the code needed & was capable of doing this, it just wasn't implemented by the developers.
[quote="omar_g"]
Very authoritive tone you've taken on there Zipper, especially since it can be done, its just not very likely to reach the general release stage due to the memory constraints of the 7650. The first Beta of Live panel (later became One2go) had all the code needed & was capable of doing this, it just wasn't implemented by the developers.[/quote]
Yes but it isnt availble to us. therefore it can not be done
8) [An emoticon to 'lighten' up the post]
