Private Call&sms Guard
8 replies · 8,532 views · Started 01 October 2008
oxfordmark wrote:Listed as working for the N96 on Symbian on.. Anyone had any luck?
I havent...
hi, it works on the N96. I just installed and used it. Just something to note:
1. If you are using a English OS N96, DO NOT buy the v3.2 one, it doesn't support. I made this mistake and am now asking for a refund on that. Instead, buy the newest v5.0. While installation, you can choose the Eng interface option.
2. Somehow on the N96, there is this Exit function that appears almost everywhere. Well, you have to be careful with this feature when you are using PCG. If you do not see that tiny icon appearing on the top left hand corner of your phone, it means that PCG is not running, and all that secret stuffs you want PCG to do for you will cease to function.
that's about it, happy trying.
mrbrownie wrote:hi, it works on the N96. I just installed and used it. Just something to note:
Where did you find v5.0. I can't find anything except v3.2 on the SymbianOn website or Handango 😞
thanks, I have tried the PCG5.1, fixed some bugs and add some useful functions than old version, nice application
the newest version have no any problem, totally hidden version can totally hidden itself, hiding the icon in the application menu, i think this feature is perfect
