Anyone got Nokia Conversation to work on the E71?
5 replies · 4,828 views · Started 07 October 2008
I really want this app but both the E70 and the E90 versions don't work on my E71. It crashes the contacts app.
Wow that's strange. Did you install the Nokia service pack or something that it said was the pre-req for Conversation to be installed? Which version worked for you? E90?
I am less interested in SMS threading, but more on being able to select a contact and seeing the communication history.
I have an E71. I don't think I did anything special before installing, I just installed it. It just worked. Sorry you're having trouble.
I just tried to look to see what version I have, but it doesn't say anywhere.
It worked!
I uninstalled the app as well as the support application and installed just the application. It gave a warning about support package not present but when you ignore the warning and install, it goes through and works fine.
Thanks for the help.
