OK...I'm not sure if someone has asked this or not, so here it goes
Before upgrading my fw, i used PC Suite to backup my phone, upgrade went fine and i went to restore my phone.
First thing I noticed was that some applications that came with the phone went missing.
Also, some themes that came pre-installed are gone.
Is there a way to restore these things that came from the operator?
I still have the file i saved on to the pc.
Appreciate all of the help in advance.
Sorry, I have the N95 8GB from Cellcom Israel
If you have "debranded" then you will lose any features/prog's that were part and parcel of your operators branded firmware.
You should not attempt to restore Settings after a debrand and upgrade as you will be attempting to restore the settings of the branded firmware which will not be compatible with your new firmware.
erakat1 wrote:OK...I'm not sure if someone has asked this or not, so here it goesBefore upgrading my fw, i used PC Suite to backup my phone, upgrade went fine and i went to restore my phone.
yeap, that's my experiences too. All the diy firmware are generic, so after several tries of diy update attempts, i always visit the nokia care center for the operator or regional customize fw, which offers more than a generic fw.😎
