N95 charger socket size?
5 replies · 5,461 views · Started 27 October 2008
Hi all, what size is the N95 charger socket? From these which one should I order?
DC Plug 0.7mm/2.5mm
DC Plug 1.1mm/3.0mm
DC Plug 1.3mm/3.45mm
DC Plug 1.45/3.45mm
DC Plug 1.7mm/4.0mm
DC Plug 2.1mm/5.0mm
DC Plug 2.5mm/5.0mm
Thanks!
whoah!! so many choices!!
i would guess its the 2.5mm but if ur having so many choices u need to find a new shop to buy from.
If your in the UK go to play.com and search for N95 and you will find your charger for quite cheap.
cant be the 2.5 one, as thats just a bit smaller than the 3.5 headphone one, and this one is much smaller. dont really need a new phone charger as i only need th connector, but may well end up having to do so... anyone know which one it is for sure?
thanks
I know credit crunch etc...but come on, you can get a whole charger for under a quid from ebay! 😉
to be honest with you it isnt the cost, i just wanted to make up the lead myself, but i guess it's looking that way...
