Any one know of a way to hack the n85 yet? or a good method of signing unsigned apps? any links would be be really helpful thx
n85 hack or certificate signing?
l1nknp4rk wrote:Any one know of a way to hack the n85 yet? or a good method of signing unsigned apps? any links would be be really helpful thx
there are no hacks for the n85 0r n96 as of yet iam sure people like binpda and dotsis are working on it so you can install any application wether its signed or not
at the moment iam using a dev cert (develepers certificate) to sign my own applications
its a bit tiresome comared to the hello carbide version etc but it works and now my unsigned applications work on my phone fine
try googling a dev cert for the n85
ill try it out thx
Getting your Dev Cert and a Signing program is the ONLY method at the moment. As the N96 / N85 and some N82 versions are un hackable.
