i want new ringtones
9210
That's a very broad statement, what exactly are you after. Wav ringtones, standard ringtones, particular genres?
standard ringtones
dr.dre
eminem
snoop
any thing![]()
Check the download section of this site or the wav files @ www.n9210.co.uk
Or ceate your own with RingMaster (www.zenobyte.com)
Rafe
thank you
i want mor)))))))))
while we are on this topic.....is there a way to convert wav to rng??
i have some of nokia's tunes in midi(which ive converted to wav) & wanted to know if i can convert it to rng...as they sound better in rng, on phones like the 8210 , 8250.
i'm going to put up many wav files on my site this weekend (unless saturday gets to wicked
). i've collected many wav's for ringers as well as messages & fax tones.
ciao
gaurav (HyPeR)
You can use a converter from a lesser phone (eg Nokia 6210), to convert the MIDI tunes to .rng, or Ringmaster. As for .wav to .rng, the program is going to be very CPU intensive and however I think of going about it, all the latent harmonics in the sound file will probably be included leaving a really bad tone. Try working out the riff you want on a keyboard or any instrument you can play, then write the tone out in RingMaster.
have just added a couple of wav's & also some rttl tones & also a ring tone convertor (for your convienence)
Also my logo page has changed a bit with priview of all the logos, instead of the zipped files.
the ring tones are yet zipped files.
i'll be putting more ringers over this weekend.
ciao
gaurv(HyPeR)
i 'm not found tones in the sites
please any one send to me any ringtones {?????.rng} type
please send to my e-mail ringtones
i havent converted into *.rng yet, i'll do that but u can download the rttl type & wav files in the xipped format from
http//angelfire.com/space/n9210/ring.html
i'll also send u the zipped files by email, till then.
ciao
HyPeR(gaurav)
thank you
put i want tons plese
any one have tones 9210 send my E-mail
[email protected][email protected]</a>
I've just sent 974 of them to you.
If you need more then you've too much time on your hands. ![]()
I hope they keep you occupied.
This is the bestest place!!!
spanker....please send me those 900+ ringers as well....
ciao
HyPeR(gaurav)
thank you all..
but i want more ![]()
hey SPANKER...send me those 974 *.rng's also....PLEEEEEAAASSSEEE.....thanks
ciao
HyPeR(gaurav)
Done
No problem
hey SPANKER....could u please email me those 974 tones as well....please...thanx
ciao
HyPeR(gaurav)
and if you e-mail them to me I'll put them up on the site if you like
Rafe ![]()
i want
top 10 tone
top 10 wav
please send my E-mail [email protected][email protected]</a>
hey SPANKER...i think u must have tried to send me that email with the ring tnes, but my server was down & so it must have bounced back...
please send me again at
thanks
HyPeR(gaurav)
Hey Spanker, like Rafe, if you send them to me I'll also put them on www.n9210.co.uk (if that's OK with you).
hey there spanker ![]()
can u hook me up with those ringtones as well ![]()
i appreciate it man ![]()
thanks
Hi, spanker
Can I have those ringtones? Thanx.
If anyone would like to download the 974 ring tones,
go to www.yourex.co.uk
on page 2 right click on the 9210.
hi, if i have a .rng file, where do i put it on my 9210?thanks you, and my apology for my ignorance.
cvsoft
Actually u can just put it anywhere... what u need to do is click browse from the profile setup... then select the ringtone...
ok, thanks man. ![]()
