Opera Mini just went up to v4.2, in beta form at least, with new Skins support, faster servers, compatibility with the mobile version of YouTube and Opera Desktop note syncing. Read on for quoted details below...
Is there an wasy way to copy over your bookmarks for 4.1 to 4.2? I thought that it would have been done automatically.
Thanks,
John
I'm sure you can sync them with opera servers before and after install, just like with all the other versions.
Beta versions are not consideret replacement for your older version. When 4.2 goes out of beta and you still have 4.1 installed it will automatically replace it and carry over all your bookmarks. At least that was the case when going from 4.0 to 4.1, so I expect it to be the same going from 4.1 to 4.2.
/Palle
using opera link bookmarks are always in sync across several versions of opera mini and opera desktop versions
Syncin' works well, however the default links get synchronized too 😞
They have to bee deleted after the synching process.
My problem was that I was not using the Opera sync function and expecting the new version just to pick up the same ones that the 4.1 version was using. I've synced now and everythings fine.
Thanks,
John
I't gonna be great..., changeable skins; better than default "red opera" skin
okay i just downloaded this to my blackberry and have no idea how to change my skin color. i saw someone say go to menu, tools, ect, but i dont even see when the menu tab is at?!! also, how do i make it into the mobile view?
