Remote S60/Infared instructions how to use...
3 replies · 2,126 views · Started 19 February 2003
instructions:
What I was doing wrong: I didn't press connectivity/Infrared 1st from the phone. Thought that because infrared starts from Remote S60 wasn't needed. (mRouter maybe running or not)
1. Start Remote S60 from pc (file/setup/IrDA) check all and press ok.
2. From phone Connectivity/Infrared
3. From phone start Remote S60/options/Infrared and choose one. If not working choose the other one.
Good luck
Hi all. I have used Remote S 60 perfectly via Infrared, and it works slow yet effective. Even trasnferred some Pocket Nancy videos and saved them. I dont have bluetooth yet, and I wanted to know how the TCP/IP works. I dialled up like the instructions have said and nothing, no connection from my PC or my phone. I waited more than 2 mins, surely it should have worked. Please someone explain how the TCP/IP works?
Anybody knows how to make it work behind a firewall?? (if possible, that is..)
Tried TCP/IP and Bluetooth successfully, but would like to be able to use it behind a firewall (at work) too.. How do you use the proxy settings it has?
