Is there any problem with Incoming Calls??
4 replies · 2,510 views · Started 19 February 2003
My incoming calls last only 2 rings max before it registers as a 'missed call'. Is there any way to extend the 'ring-duration' of incoming calls?
My O2-XDA has a feature to set the ring-duration for max 30secs which is pretty neat.
maybe this has something to do with your voice mailbox. But I don't know, where you can setup, when your mailbox should answer the call. Maybe someone can help
From what I know about this is that your setting on the call diverts are set to a time quicker than usual you can call your service provider to fix this to a more reasonable time to divert.
i also notice that the p800 rings twice until the call is a missed call......
how comes its like that?
I posted similar thread in howard & this was what I've got, courtesy of MV4. Have tried it & it works !!
Hope it works for those having similar problems.
http://www.howardforums.com/showthread.php?s=&threadid=100680
