Afternoon all,
Is there a TV output cable available to purchased for the Innov8 yet? The only ones i can find are from a store on ebay.....from Hong Kong.....:con?
Cheers.
Afternoon all,
Cheers.
I got a Nokia branded one, with a 3.5mm jack. From Hong Kong! Velly cheap my fliend!
Cheers, may aswell plum for one of those then. Theyre only a couple of ���.
I wonder if one of these would do the job....
http://www.maplin.co.uk/Module.aspx?ModuleNo=29308
or
http://www.maplin.co.uk/Module.aspx?ModuleNo=33039
but which one, the sony or the panasonic. I don't fancy spending �8+ on the wrong one. or maybe neither would work because samsung decided to use a different combination for the audio and video signals
same thing for a little less money:
http://www.tvcables.co.uk/cgi-bin/tvcables/camcorder-3xphono.html?id=Wnuzrq7v
mrFlibble47 wrote:I wonder if one of these would do the job....http://www.maplin.co.uk/Module.aspx?ModuleNo=29308
or
tried both of them but did not work. had to take them both back to Maplin!
I bought this one off the good old Ebay : http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370073721320
Hope this helps
arsenal401 wrote:tried both of them but did not work. had to take them both back to Maplin!
that sucks 😞 glad I found out without having to buy either myself though 😊
at least you got one in the end.
according to my supplier they'll be available in Australia mid-january. not sure, but im assuming they're official brand. will definitely be more expensive arsenal's ebay link so I think i'll give that a go first...
The Nokia ones work perfectly from my experience, so I'd advise people to just use those.
i decided to order one of these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370073721320
called by the seller an "AV Cable/Lead For ARCHOS 404 500 504 604 704 705 WiFi"
mine was white and fortunately worked perfectly when it arrived 😊
mrFlibble47 wrote:i decided to order one of these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370073721320called by the seller an "AV Cable/Lead For ARCHOS 404 500 504 604 704 705 WiFi"
Glad i was of help there matey
