SmartConnect by Birdstep
2 replies · 7,991 views · Started 27 November 2008
Hello to everybody,
I have a new Nokia E51, and i would like to setup a connections manager that automatically select the best wifi preregistered connections. I found, in the download page of the phone, a programm called SmartConnect by BirdStep that does exaclty what i need and seems to be free. After installed it, when i try to connect it tells me "License not valid", but i don't know how to get a license (Doesn't it free?).
Can you help me? Thanks
Hi
Uninstall SmartConnect, use File Manager to remove the birdstep folder in the others folder, refresh the Nokia Download list and install SmartConnect again.
That should do the trick.
- Tkn82
