Available on NSU. Change log:
New features and applications:
- DVB-H accessory support (SU-33W)
- Nokia software checker application
- Support forNokia MU-44 16GB microSD memory card
Changes/improvements:
- Bad sound quality using BT headsets (CAP 97705)
- Cannot display the video under edit menu (CAP 99698)
- Keypad no response after make call with slide close (CAP 99169)
- Problems with finding contacts starting by "CH" (CAP 97026)
- Music player keep searching new songs when activated (CAP 97082)
- Message type changed to multimedia message (CAP 99880)
- Video recording quality improvement
- Imaging quality improvements, better colours saturation and flash
- Defaul setting change: Closing slide doesn’t disconnect call
- Short slide key illumination applied for Java application compatibility
- "Video call" is shown in Options when highlighting a contact in Space UI.
- Not detecting always wall charger -> Not charging
- 2G cannot connect to GPRS service in some cities in China
- Non stop Music Player "Library update"
- FMTX: The audio is routed to DUT speaker after receiving a message when FM
transmitter is transmitting audio.
- Predefined contacts does not support Chinese characters
- APN setting for Vodafone Mobile connect "Promt Password is set to Yes"
- Audio >> downlink quality
- Some of the S60 key presses are not registered by device
- Google Maps application not working with "Vodafone live!" access point
- Network level icon is not shown during VT call
- ITU is not responding when MO is done where slide is closed and opened when call
is established
- Long press of Media keys prev/next not working correctly for local videos
- DTMF tones sent from prepaid line to *600 (or *400) are not received by NW
- OFR_pop-up at boot about positioning
- Orange enterprises APN is used by default in the email Wizard
- Pod cast: messed up characters
- All key presses are not registered by device
- E-mail address limiting to max 30 characters
- SMS converting to MMS if more than 20 recipients
There is no update for PC 0574325 right now, just checked it. It's a unbranded German phone.
I've a Euro product code origin Poland and it updated fine.
I managed it now. Changed PC to Euro1 0555817 which also includes German language beside French, Spanisch, English, Portugese. Finally got rid of turkish 😊
just updated mine vis NSU for emerging asia code, it rocks !!!
just from playing around a bit .. it actually seems to scroll properly.
No major pain - gotta love FP2 .. no backup required .. though you'd be mad not to! 😉
"no user files or settings were harmed in the making of this upgrade" 😊
yeah, I think the scroll feels a bit better too... still cant use it how Id like tho.
can this be updated without pc-suite? Thanks
I've got an N85 sourced from the Nokia online store. Used NSS to change the product code to 0572869 as no update available on original product code. Now updated.
As I previously had an N95 I was used to deleting all my memory card-installed applications PRIOR to firmware updates and then reinstalling each individually after the update had completed. I also had to then re-sync all my contacts and calendar bits and pieces and generally spend around half an hour customising settings, etc.
It would appear the N85 firmware update does not overwrite personal data. All my contacts and calendar info, personalised ring tone settings, etc were all still there post update although I did remove the memory card apps first as I was used to doing that with the N95. Just reinstalling them now.
Can't say I've noticed any immediate difference in the few minutes I've been using the N85 post update.
F
Can it be updated without the NSU like on the air?
mfzaman wrote:Can it be updated without the NSU like on the air?
Upgrades .. its seems no one is game to try it! Wanna test it out for us?! 😉
I suspect you should be able to use FOTA (we know its not really free most places) I'd be making sure I had a Wifi connection for this.
Why not use NSU ??
Can someone please tell me how you changed the product code for the N85? I have a N79 and I guess they will be the same. Everytime I use NSS I get an error messege when I attempt something.
Jayd wrote:Can someone please tell me how you changed the product code for the N85? I have a N79 and I guess they will be the same. Everytime I use NSS I get an error messege when I attempt something.
http://www.allaboutsymbian.com/forum//forum/thread/67122/
F
ffcphone wrote:http://www.allaboutsymbian.com/forum//forum/thread/67122/F
Thanks but I have NSS installed but my problem is that it wont recognise my N79 other phones work ok.
should I take out the memory card before updating? or should i leave it in ? do i have to erase everything on card and phone memory before updating?
l1nknp4rk wrote:should I take out the memory card before updating? or should i leave it in ? do i have to erase everything on card and phone memory before updating?
In fact you don't even have to back anything up .. but you'd be mad not to.
"No user files or settings were harmed in the making of this upgrade" 😊
Read post #9 above. I wondered the same thing.
F
i tried updating fw but after the fw downloads and it tries installing and says 15 min remaining, my phone screen goes black, looks like its off and the light around the naviweel stays lit and the update never progresses. after a while the phone restarts...i think i have the malaysian/singapore version phone.
I changed my code to Euro 1 .. and tried again .. worked fine .. you have to be a little patient OR you could try the FOTA update (if you have WiFi)
Tools / Utilities / Device manager / Options .. Check for updates ..
Good luck! 😊
I upgraded the firmware via the process outlined here (works like a charm) OTA (UTMS) does not work, had to go via the software.
However, I feel like my calls drop more now with this upgrade, only on 3g however
Original Product code: 0569601: Arabic 1
Current Product code: Europe 1
when i try updating through my phone throght tools/utilities/dev manager it says no update available but when i plug into cpu and update through nokia updating software it says update available/
Does anyone know if Windows Live Messenger now works with the new firmware? I can't upgrade yet since they haven't released it for Hong Kong phones 😞
NSU wouldn't upgrade my firmware, but when I tried thru the phone it worked just fine! Product code 0573729
