v11 firmware to hit 5800 XpressMusic - BTDT
7 replies · 3,117 views · Started 23 December 2008
S60Inside is reporting that v11.0.008 firmware is about to hit the 5800 - Been There Done That, in my case, since this 9th Dec firmware was the one loaded on our review unit 8-) - still, watch NSU if you're still on v10 and avail yourself in a day or so's time to a load of bug fixes!
After a few days with using 5800(v10), I can't find any options about upup.
Did it remove?
Yeah everyone is right. Version 11 is still not on proper release. I'm presuming it'll be available soon.
Does anyone know if i do a firmware update over the air on my phone does it keep all my applications that i installed or do i have to start from scratch again re installing them
Djbriandowling, in theory you shouldn't have to reinstall anything, but in real life it may be worth taking a backup of all your data using PC Suite. Some phones do OTA updates without any problems, others do have problems.
