Receiving calls using fring
2 replies · 4,380 views · Started 02 January 2009
Hi! Just learned that I can make calls through fring using skypeout. But in order to receive calls, I have to have fring always-on. Hm, drains battery fast? Is there any way around it? Thanks.
I have the same problem with Fring. It can drain my battery within a few hours without even using it. I don't have the same problem using Truphone.
[email protected] wrote:I have the same problem with Fring. It can drain my battery within a few hours without even using it. I don't have the same problem using Truphone.
Ah, thanks for the info. Truephone even has the call forwarding feature when offline. Even better. Thanks again😊
