N95 8G Wont Update After Debranding
5 replies · 3,689 views · Started 04 January 2009
Hello, I have a Nokia N95 8G US version and I have changed the product code so that I can get Arabic txt. However, after I changed the product code successfully using NSS, I tried to use Nokia Software Updater and it says there is no updated at this time,but I know there is. Can anyone help me with this problem. The product codes that I used is 0534856 and 0550805 nether allowed an update afterwords.
Where did you get your product codes from?
Make sure you use the correct N95 model product codes, for example, ensure your not in fact trying an N95-2(Europe) product code instead of the N95-4(N-American)
Latest available software for Nokia N95, product code 0534856
Version: 30.0.015
Latest available software for Nokia N95 8GB, product code 0550805
Version: 30.0.018
These were checked on the nokia site here:-
http://europe.nokia.com/A4577224#
As you can see, the first code relates to the N95-1 (classic) and the second looks to be for the European 8GB (N95-2) version. Neither of which are designed to work on the NAM version which because it is sold in North America is not deemed to require the Arabic language variations as far as I can ascertain.
