Hello, I have a Nokia N95 8GB and I was wondering how to install applications for it. I hear there are lots of cool apps I can download and install, but I don't know how to do it. Thanks.
Installing apps on nokia n95 8gb
1. Download Nokia PC Suite to your computer.
2. Connect your phone to computer via USB lead supplied.
3. Select PC suite mode on phone
4. Click on Application Installer in PC Suite.
Thank you, are these apps for free or is there a charge for them? I heard that there are lots of free apps on the internet that I can get for my phone.
There is lot's of free stuff. Just Google it.
Here's a start:-
http://www.nokia.com/betalabs/applications
Thanks for all the help. Does my phone have to be hacked to download all that stuff, or can I download them from as is?
You just download as is. That's the whole point of a smartphone!
yeah smartphones are SUPPOSED to install tons of apps. you should start off with google maps since its a free app and pretty awesome for a mobile phone. even has street view now, and satelllite view. its my most used app on my n95, but you need to use data plan with it, or you can use wifi.
