I need help. My outgoing sms icon is currently stuck. I've tried removing the battery but the icon is still popping up. It started to happen when I was unable to send a sms - sending failed error message. Any ideas? I'd rather not reformat my phone for the 5th time this week 🙄 .
Stuck outgoing message icon
You could try checking your Outbox and see if there's something still stuck in there - if there is you can manually re-send it or delete it.
i've the same problem...
no items outgoing but the icon light up.
Have you solved this problem?
tnks
bit of an old post so you may not get an answer from them 😉
By outgoing sms icon you mean the one with the wavey lines... like -
or just a static message icon?
