Switching between Wifi and 3G
8 replies · 3,335 views · Started 22 January 2009
Hi
Is there any way to get the N95 8GB to automatically switch between wifi and 3G? Basically, when Im in the office or at home I want the phone to use wifi for gmail and other apps then when I walk away from those places it switches back to 3G for gmail and the other stuff.
Is this possible??
Thanks!
there should be an option in the menu of the app your using to switch the connection, i know there is for web.....
I've seen that one. But I was hoping there would be a way of automatically forcing all apps to use either wifi or 3g depending on if the phone is in a wifi area or not?
Done the trick perfectly so far, thanks for your help!
I never realised how quickly the battery would be hit though!
