2 problems with my n95 8gb (fw 31.0.015)
3 replies · 5,545 views · Started 22 January 2009
1. I cant install python. It tells me that the software is not supported.
2. When trying the Drakkarious Hack, using hellocarbide, after pressing "menu1" i dont get the option to press "yes". It just goes back to the blank screen. Is there a way around this or is there another hack that doesn't use hellocarbide.
Obviously i am asking these questions as i want to put some decent apps on my phone. What is the point of having an N95 if all it can be used for is phoning and texting? 🙄
What are the "decent apps" that require hacking the firmware and can't be put on your phone otherwise?
bang whos next?? well it wasnt you in the queue to SEARCH!!!!
if you did you would find a number of answers:
A) No hacking talk on this forum
B) You cannot hack this firmware
C) You are supposed to search before asking questions
D) No one likes people that sign up just to ask a question then go away again
thehaggishunter wrote:bang whos next?? well it wasnt you in the queue to SEARCH!!!!
A) didnt know
B) didnt know
C) I did a search and came up with nothing, hence the question.
D) Ask me a question and if i know the answer, i will answer it.
Here's one... Why are you such a smart arse MR 32 posts?
