Nokia 5800 via PLAY.COM for �227.99 - Quidco
7 replies · 3,966 views · Started 24 January 2009
I have just pre-ordered my 5800 Xpressmusic on www.play.com for �227.99 using the RAC code and I will also get �8.40 back via Quidco, so that's a nice new 5800 for less than �220 and the delivery is free. Just gotta wait until the end of next week hopefully.
Bargain.
valerebel
I used up my RAC code on something else. Its once only
I got mine from nokia �252 lese �14 quid co, so �238
topgazza wrote:What RAC code is that Valerebel ?
Go to HotUKdeals and all will be explained.
Basically, you can obtain a code unique to you by asking the RAC for it by making them think you are an RAC Direct customer. Although you are prompted for a name, address, phone number, email etc, there is no validation on them as the code is given to you immediately. You can be whoever you want.
I have ordered mine (now due for release 30/1/09) and Quidco commission is appearing as �8.40.
Good luck.
valerebel
colonel wrote:I used up my RAC code on something else. Its once only
Delete the appropriate cookie and you should be fine.
valerebel
Indeed that works fine. I could actually us my sons UCAS student number to get the same discount. �227 for a delivered free Nokia 5800 ?
I'll have 5 guv'ner
topgazza wrote:Indeed that works fine. I could actually us my sons UCAS student number to get the same discount. �227 for a delivered free Nokia 5800 ?
I'll have 5 guv'ner
Did you go through Quidco for an extra 4% cashback?
valerebel
Got fed up of waiting, release date keeps altering, so I cancelled my order with Play.com and thought I'd get the �209 PAYG deal at the CPW.
valerebel
