Hi
I have an N79 that seems to have got its wireless APs in a mess. Is there a way of deleting them? The instructions for doing the same thing on N85, etc don't work, as there isn't an "Access points" option in Settings | Connection.
Mike
Hi
Mike
michaelh wrote:HiI have an N79 that seems to have got its wireless APs in a mess. Is there a way of deleting them? The instructions for doing the same thing on N85, etc don't work, as there isn't an "Access points" option in Settings | Connection.
Mike
then look under Internet, Multimedia Msg for defined access points.
Open then choose options to delete/rename and! "organise" 😊
Good luck! (this assumes the N79 looks the same as the N85 menu)
Mike
Try this:
Menu
Tools
Settings
Connection
Destinations
Hope that helped 😊
Thanks very much xnickx - that did the trick 😊
