5800 - Comes With Music?
3 replies · 4,930 views · Started 05 February 2009
With a recent purchase of the 5800XM, should that give the one year access to the Comes With Music service? Apparently it needs a pin code to activate.
I've not looked at Comes With Music til now, and thought the 5800XM would be compatible. Does anyone know for sure?
Jay3gsm wrote:With a recent purchase of the 5800XM, should that give the one year access to the Comes With Music service? Apparently it needs a pin code to activate.
as far as i know none of the 5800's currently sold come with the "comes with music" 12 months subscription yet. normally i guess a code would be included in the box with the phone.
No you would have to buy a specific Comes with Music 5800 (probably branded with a stripey sleeve). These are not available yet.
It is compatible in the sense it will technically be fine...
BTW you wont be able to buy another CwM handset (e.g. cheap 5310) and activate it on the 5800. The pin is specific to the handset model.
Thanks for that. I was curious as on a few blogs it was mentioned CWM was included, and I couldn't find out for sure.
