Problem solved!
Can't delete folder!
Is it a preinstalled Nokia folder or one that you created?
[email protected] wrote:Is it a preinstalled Nokia folder or one that you created?
I've created it.
* Green 3 combo WILL get rid of the file but will also wipe everything on the phone. Before that you could try using YBrowser and editing the attributes so that its not protected.
