Spiderman 3 Invalid Key
8 replies · 4,256 views · Started 24 February 2009
i just updated my phone to version v20.0.16. phone branded vodafone.
unfortunately now i can't play the preloaded spiderman 3 movie as it days activation key has expir'd and it is invalid.
advices please to remedy the situation, thx
Restore the PC Suite backup you made before updating the firmware. It should restore the activation key.
If you didn't make a backup, then I imagine that you might just as well delete the movie and free up the disk space.
N/A wrote:Restore the PC Suite backup you made before updating the firmware. It should restore the activation key.
i lost my back up 😞
how to valid the activation key, is there a way?
Be aware that restoring a backup after FW flashing can cause problems.
You are probably better off deleting the movie, which I assume you have already watched several times?
dez_borders wrote:Be aware that restoring a backup after FW flashing can cause problems.
thanks anyway..
still got my spiderman 3 after 6 firmware updates and alyways used back up.
yes yes Ive only watched the film once though 😉....
