Is it possible to leave messages on server, when using P800 email client, and how, do i set that ?
Leave Message on server
I�m guessing use an IMAP server isn�t the answer you�re looking for... 😉
[quote="dezoe"]I�m guessing use an IMAP server isn�t the answer you�re looking for... 😉[/quote]
I've tried POP and IMAP, and it makes no difference.... need an option to select "leave on server"... and the P800, as best as I can tell, doesn't have that.
That's what IMAP is all about 😊 I have an IMAP server, but at work i have an pop3 / exchange 😊 So I really need it
I did not find any such setting on P800 but it leaves the messages on the server by default.
Jimbo
