Anyone using stereo bluetooth, how's battery life?
4 replies · 4,231 views · Started 02 March 2009
I'm thinking of picking up some bluetooth stereo headphones, but only if I can get through a day easily without running out of power.
Usage pattern is normally about 40 mins listening plus some web browsing on the train to work some intermittent listening and browsing in work, then another 40 mins on the way home along with a bunch of texts throughout. Anyone have any experience as to how the battery will cope with this, or generally how long you can use a2dp for?
bluetooth kills the 5800, but i dont use it as much so i have never fully used the battery on the 5800 till its end
ahmedjhang wrote:bluetooth kills the 5800, but i dont use it as much so i have never fully used the battery on the 5800 till its end
I use my 5800 and go running and work out at the gym with Stereo bluetooth for an hour or two and see barely a blip in battery life...
I think it's working pretty good for me.
FWIW: I use http://www.jaybirdgear.com headphones and they rock.
tx
P
I'm using Motorola S9 and i lasts two days with almost 1.5 hrs. a day of using plus about 15-30min. of browsing and time to time calls and SMS
