Nokia 7650 compatibility with Nokia 7210 ?
6 replies · 2,428 views · Started 26 February 2003
Hi
I've purchased one Nokia 7650, my bro has the Nokia 7210.
I've tried to send a pic to the Nokia 7210 via Irda. But the operation failed.
Contact and calendar transfert work good via Irda.
Is there one solution ? Can I send pic to a Nokia 7210 ?
Please help me !
Thanx 😉
I have heard that early versions of the 7210 had a firmware version that had a problem recieving pictures fro the 7650, you can probably check this with a Nokia Service Centre in your area.
I am not sure if there are any threads in this forum regarding image sending between the devices, have a search to see.
Good luck
Bob
If you have v3.08 or v3.09 for the 7210 firmware then there is a compatability issue with the 7650.
Type *#0000# to find your version.
Good luck
Bob 😃
I've V4.18 on my 6610 and I cannot recieve images over Irda from my 7650. Same with my friend's 6100 and 7210.
[quote="Bob"]If you have v3.08 or v3.09 for the 7210 firmware then there is a compatability issue with the 7650.
Good luck
Bob 😃[/quote]
The 7210 firmware is V3.09. :-?
If your 7210 is under wananty then go to a Nokia Service Centre for an upgrade, which should be free and take about 2 or 3 hours.
Good luck.
As for the other phones, I havn't heard about any problems, best thing you can do is ask at a NSC.
Good luck all.
Bob
