no 3g
1 replies · 3,137 views · Started 17 March 2009
Which phone model do you have?
When did it work the last time?
When did you first notice it not working?
What happened/changed between the time it last worked and when you fiirst noticed it is not working?
For example, did you update the phone firmware?
Or did you go to a different location?
Or did you change the operator/SIM card?
Have you called your network operator (carrier, service provider) and asked them, if there's something wrong with your subscription, or their network?
Does it work if you use another SIM card?
Does your SIM card work, if you use it in another phone?
Where in the world are you?
