WAP Question
8 replies · 2,124 views · Started 27 February 2003
Hi, I'm trying to get my Hotmail through WAP but everytime I try to login to msn.mobile.com it allows me to enter my username & password but then it just stops and eventually gives me a WAP: Time-Out error (same happens when I try to download from sites).
I know WAP Hotmail is possible, even seen screengrabs of it running but it's terribly frustrating not to be able to get it to work!
I've managed to get Hotmail to work with Doris but it's very cumbersome to view the normal Hotmail site using HTML (takes forever to read through!)
Is there anyway to change the WAP Timeout setting on the 7650?
FYI, my provider is Dutchtone in Holland and I'm using GPRS but I had the same problem when I was still using a GSM connection.
Thanks in advance for any answers
Peace, Ruben
Try signing up at http://www.anytimenow.com/
and then using wap page http://www.anytimenow.com/wd/
There other ones too. Try a Google search.
HI!..
i use only Doris Web Browser to enter Hotmail or any other page...
i don't tested on WAP...
i enter sometimes to wap.yahoo.com and there you can see email or yahoo messenger..
May be the WAP version don't work on hotmail?
not sure..
cya!
Hi all! I want to install oplayer but i can't , anyone to send me this application by email? Thanks
I use WAP hotmail, all the time, occasionally it will time out when Hotmail is busy, not sure you can change the timeout settings.
Thou I use the url http://mobile.msn.com/pocketpc
as msn serve up the html version on my 3650 instead of the WAP version. adding the /pocketpc cures this problem - and appears faster to me too so perhaps you should give it a try too and you may not timeout...
Best
Will
Come on guys. Stop asking this and that from wap. I also want many things through wap now that i an away from my pc but i am not asking for them. So stop asking AEFOX to send u things to your email and leave him update his wap site... 😃 😃
