One regression I noticed in V20 is that the left and right arrows in the call log have gone, so you cannot press the dial (Green) button and then left/left to see missed calls. You have to go to Logs in applications... According to the "Help" you should be able to select the tab direcvtly instead but they are greyed out.
Anyone else annoyed at this ? Is there a setting anywhere ?
I think you're mistaken. You just click on the missed calls icon, after you press the green call key, and you're there!
Indeed, works as expected for me as well.
Tried again, they are still greyed out and not responding. Rats.
Bit of a long shot but I have heard reports that some themes can have wierd effects on the phone.
If you're running any 3rd party themes have you tried disabling them to see if you still get the problem ?
Exactly this. Was running with one of Piezo's (?) themes which looks great, but made the tabs not work. Back to factory default theme for now and happy again.
Thanks!
