I've got Smartlight and with one exception it does the job. The problem is you have to launch it every time you turn on the phone. Does anyone know of an application that does the same job but runs as a service?
Anything Similar to Smartlight?
Don't know of any others but if you have SmartPhoneWare's Best Profiles installed, you can set it to automatically run any app you like when each profile is activated.
For instance, when I had my N95 I would set the sat nav program to run whenever the phone switched to the 'Car Kit' profile.
It would then stay active regardless of what profile I subsequently selected.
Should work.....let me know.
Thanks, I'll check it out.
