Replacement of P800 Display
2 replies · 2,960 views · Started 28 February 2003
Does anybody know where to get a cheap replacement display for the
P800.
I think the most expensive way is at a SE Service Point.
Maybe someone has got a cheaper solution. I only need the display.
I'm able to do the replacement by myself
There is one way for free. Steel someone else's p800. That way you will have every simple thing you want to replace now or later to your p800.for free... 😃
